LS flywheel to th400 trans
Old 09-19-2018, 06:46 AM
Go5.3tt06's Avatar
Default LS flywheel to th400 trans
Can you correct me which flywheel I can get it from summit that is no need spacer. I have lsx 427 want find right flywheel to convert for th400 trans??????????
Old 09-19-2018, 08:48 AM
Dusty05's Avatar
Circle D makes a nice one. From what I remember when putting mine together, the converter needs to be made to work with the th400 (longer hub) to ls swap or you have to use the spacer.
Old 09-20-2018, 03:50 PM
Go5.3tt06's Avatar
I was going hold for circle d flywheel they cost 500, I kinda don't want run spacer if it is need to run with spacer. Is this correct part? https://www.summitracing.com/parts/add-712500a?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-advance-adapters&gclid=EAIaIQobChMI-dG-nrrK3QIVi4rICh1iNAUfEAQYBCABEgKdy_D_BwE
https://www.summitracing.com/parts/h...make/chevrolet
Old 09-21-2018, 09:26 AM
Dusty05's Avatar
Is your converter made to go from TH400 to LS or TH400 to SBC? If it's made for SBC, then you'll need the spacer.
2muchboostNY
02-11-2015 02:31 PM
468BIGBLOCK
05-15-2013 04:02 PM
y2k_ta
05-14-2009 10:45 AM
Dock Rocker
09-14-2007 05:41 PM
RERICK
03-04-2007 01:37 PM
Quick Reply: LS flywheel to th400 trans
