CNC PP 5.3l 706 heads / What injectors to runs?
I picked up a set of Fully CNC'ed Ported and polished 706 heads and im planning on getting them looked over and throw them on my setup that is in my signature.
I have a set of 24.7lb flow matched injectors now, do you think with the heads i would have to jump up injector size? Not sure if im going to run the stock truck intake or jump up to a TBSS intake just yet. Thoughts? Advice? |
I run the 8.1 31lb injectors with my h/c LS1....They work but I may step up to 42lb marines once I start using dope...
-For you I would get 42lb if you plan on stopping now, or 60 lb If you plan on taking it further...(past 450 rwhp) |
I run regular 8.1L injectors, they are ~31lbs. My IDC is ~72%
