-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   cleaning ports? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/cleaning-ports-475188/)
40series Jan 7, 2011 12:27 AM
cleaning ports?
how do you clean ports when the manifold is off?
Cleaner?
Tools?
Technique?
Beatdown Z Jan 7, 2011 04:15 PM
I just hit my ports with some SeaFoam that comes in the aerosol can(called Deep Creep). I just sprayed a little bit, rubbed it with my finger, then sprayed a little more and called it good. I really don't see a need or benefit to have them totally clean...
ezdaar Jan 7, 2011 04:49 PM
Berrymans B-12 will remove ALL carbon and oil from ANYTHING!
Spray it on carbon buildup, let it dry then simply use a vacume to suck it all out of the port.
It will turn all flaky if you spray it gently then let it dry.
dmelvin Jan 7, 2011 06:03 PM
Won't it also like... blind you and melt your skin off?
