-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Ceramic Coating/High Temp Paint ? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/ceramic-coating-high-temp-paint-476329/)
Steve-O-08 Jan 24, 2011 04:59 PM
Just wondering, can ceramic coating be touched up? or can it be painted over with a high temp paint? just curious.
low2001gmc Jan 24, 2011 07:24 PM
i bought some used with ceramic coated jba shorties for my daily driver and they had surface corrosion. i lightly sanded them just enough to knock off the surface corrosion. i then used some silver high heat paint to recoat them. i read the instructions on back of the paint can and put them in the home oven as instructed. they came out looking like new and are holding up. to think i paid 65 shipped for them and like 7 for paint... :) i figured what i got to lose....
blueflamed03 Jan 25, 2011 09:34 AM
is they are just dirty, just warm water and a soapy SOS pad...cleans them right up.
Steve-O-08 Jan 25, 2011 11:22 AM
No they aren't dirty. I plan on cutting off the egr/air tubes and was thinking if a high temp header paint would stick to the coating. there is also some surface rust around the collector. I was thinking the ceramic that is on there would help keep the paint fron burning off. Just looking into alternatives to having them recoated.
AKlowriderZ71 Jan 25, 2011 07:26 PM
My local powerdercoating guy says that they will clean up with Mother's aluminum polish. Maybe a little steel-wool first, depending on how bad they are. Might be worth trying.
Steve-O-08 Jan 26, 2011 12:18 PM
I'm not trying to clean them up. I am going to be cutting off the EGR port because it's damaged.
Steve-O-08 Jan 30, 2011 01:49 PM
Anyone?
