Can you guys help me fill in the blanks?
Old Apr 14, 2011 | 11:49 AM
06Sierra2's Avatar
nice truck! the 224r cam has a little less duration and almost the same lift. i think it would be a little more dd friendly for u and u could get away with a little less stall. i think you would be happy with something like a tsp 224r or tr220 on like a 112 lsa with around a 2800 stall. both are proven off the shelf cams and would be tame in a 6.0. Im running the 224r in a 5.3 with a 3200 as a dd but circle d has a 2800 single disk for 375 shipped. throw a big trans cooler on it and you would still retain towing capacity imo
Old Apr 14, 2011 | 12:48 PM
kode-x-kustoms's Avatar
Thanks! Ok just so I understand a lower duration cam would make more torque? And would the amount of lift affect the torque? Would the 220 be too small?
And as for the converter, I have a 4L80E with a lock up converter from the factory. That is why I was asking about the multi disc conveter.
Sorry if I seem like a newb like I said I get very timid of doing stuff like this to my DD just for the fact that I am not always the one driving the truck. So I could throw a huge cam in it and I would not mind, but the poor soul who uses it to get hay and feed may not enjoy it.
Thanks
Kody
Old Apr 15, 2011 | 07:24 AM
Hey guys,
I have been looking and it seems I can get a custom cam through texas-speed for the same price as a off the shelf cam.
Would I benefit from getting a custom cam to get a little more out of my 6.0? or should I just stick to a off the shelf cam?
Thanks
Kody
Old Apr 15, 2011 | 07:31 AM
dmelvin's Avatar
If you're going to get a custom cam I'd suggest getting one spec'd out by PatG
Old Apr 15, 2011 | 08:29 AM
mhotrodscooter's Avatar
Custom cam would be your best bet.. You can have it design for what you have now or for what you'll be swapping too.
Old Apr 15, 2011 | 10:24 AM
I will see what pat g says.
I am also wondering, my truck has almost 135,000 miles on it. It has had the oil changed very regularly should I go ahead and get new lifters as well?
Thanks
Kody
Old Apr 15, 2011 | 12:49 PM
dmelvin's Avatar
Since you're pulling the heads, I'd go ahead and change lifters and lifter trays, but that's just me.
Old Apr 15, 2011 | 01:23 PM
Well would milling the stock 317's be worth it? I already got a quote locally and they said 125$ minus new gaskets. If it only nets me 5hp I will save the cash to put towards lifters or somthing like that.
Thanks
Kody
Old Apr 15, 2011 | 02:58 PM
GM-only's Avatar
pat g is the man when it comes to cams. i read a ton of his posts before i joined. guy pretty much has it figured out. i think that the 220 would be perfect. 6.0 is a pretty big motor so i think that the 220 would still be good for some low end torque where as with a 5.3 it would be a bit more mid to high range. 125 for the heads sounds alittle high. arent the ls3 heads 300 bucks brand new? i would probably go ahead and get a new timing chain while your in there. i dont know much about converters but i have read alot about the yank converters. they sound pretty good.
Old Apr 20, 2011 | 08:05 PM
Hey guys,
Sorry for not getting back quicker, I had a job interview friday and the guy will give me a answer if I got the job or not on top of my dad possibly getting a job working with him.
Anyways, I have been looking at TBSS intakes, Worth it, yeh or neh?
I am trying to get every little detail planned out before I have PatG spec the cam.
Thanks
Kody
