can I do away with the fuel evap system?
I bought the new edelbrock ls xt intake and I have no idea what to do with the evap system any ideas? What are you guys doing with the victor jr intakes?
I believe that there is one valve that you must retain or you will have problems with the pump kicking off when trying to fuel the gas tank (might be the ORVR or OCVR valve or something like that...once again my memory is foggy and I can only remember bits and pieces :bang: )
Yes you can. Just vent your tank to the atmosphere. I have info bookmarked at home I'll send you
Originally Posted by DozerDan
(Post 4178052)
You don't need your evap equipment for state visual inspection? |
cool so I can just mount the pump and let it go in the atmosphere? I would love the info you got at home
It wouldnt be hard to plumb the EVAP by tapping a hole into the intake, or by t-ing an already existing vacuum source.
having the EVAP purge hooked up or not hooked up will have ZERO effect on filling at the pumps. venting the EVAP to the atmosphere can result in a gas smell from your truck. I personally would just hook up the EVAP purge solenoid and keep ito operational. Just my opinion. peace Hog |
Originally Posted by hog
(Post 4179353)
having the EVAP purge hooked up or not hooked up will have ZERO effect on filling at the pumps. venting the EVAP to the atmosphere can result in a gas smell from your truck. I personally would just hook up the EVAP purge solenoid and keep ito operational. Just my opinion. peace Hog *EDIT* I'm referring to removing the entire system though, including the canister, I believe that is where the problem will arise. I agree though that I would just hook up the purge and keep it operational also... |
so hook it up and dont worry about running a hose to it. Just plug in the sensor and hide it?
My evap hose got burnt in a fire... I have NO EVAP
Originally Posted by Dark Halo
(Post 4179599)
| All times are GMT -5. The time now is 01:02 AM. |
