cam swap, would it be worth it for my truck?
Old Dec 8, 2005 | 11:52 AM
oneslammedgmc's Avatar
Default cam swap, would it be worth it for my truck?
Ive got a 90 gmc sierra. I am hoping that by march i will start my carb swap on my truck. I was thinking about also swapping out the cam, since i would have the intake and valve covers off at the same time. The only thing is that my truck has 154,000 miles on the stock 350. Would it be worth the trouble to swap the cam w hen i do the carb swap. I dont want to go witha radical cam or anything, just something with a little more lift and duration. The cam that i was really looking into is the lunati voodoo cam with the jegs part number: 638-60101lk. It is 256 advanced duration and ..454" lift. It is good for the power range of 1000-5500. I figured this cam wasnt too big and was also ideal for the rpm range that i drive . Id appreciate any comments from anyone on this. I would love to swap the cam out for the extra power and sound, but i dont want to do it if its a waste of time on my motor with as many miles as its got.
Old Dec 8, 2005 | 04:24 PM
Tractionless's Avatar
Id say go with the cam swap. I think the original 350 would work just find with the carb, intake, and cam upgrade even at 150K.
You can also look for a low milage 350 short block and add the new carb, intake, and cam plus the heads, pan, etc. from the original original 350. You should be able to find one pretty cheap.
I would also recommend some LT headers to help the new cam breath better.
Hope this helps.
steves86ta
Jul 28, 2015 10:21 AM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
Aboss
Jul 9, 2015 10:28 AM
mrgrim
Jul 8, 2015 08:12 AM
