Cam questions
Old Jun 18, 2007 | 10:44 PM
truckmann's Avatar
I put the converter in with the FLT. My stock transmission was slipping badly in 2nd gear at about 95k miles. I think it's a crap shoot on the tranny. You can swap in a bigger cam without a stall and still run fine. You probably won't pick up much speed at the track, depending on the size of the cam until you get a stall. Just start saving some money so you will be ready for a new trans when its needed...
Old Jun 18, 2007 | 11:21 PM
Jeff12's Avatar
when my tranny does give out, im just going to have to bribe the technician and have him tell my dad that it was a faulty trans. then ill tell him to get me a nice flt!
Old Jun 19, 2007 | 11:40 AM
Jeff12's Avatar
is the vinci cam "the trucker" DUR @ .004" 278*/ 286* DUR @ .050" 216*/ 224* LIFT.551/.551 OVERLAP 53* LSA 115* concidered a "big cam". i have a 5.3L and im going for a agressive, choppy idle cam rpm range from around 2-6k. would this be a good choice or what would you suggest
Old Jun 19, 2007 | 12:56 PM
truckmann's Avatar
I think that cam is on the upper end for a 5.3L and it sounds like a decent cam. You could probaly go a little bigger if you want and from what I understand something on a tighter LSA should have more lope to it. Tuning will play a factor in that also. Maybe someone with more cam knowledge will chime in here.
Old Jun 19, 2007 | 01:08 PM
ChevyThunder17's Avatar
No, you have the right idea. That's an exhaust happy cam, make sure you have headers and a good catback as backpressure is not your friend. A 224/224 would be better for the power range you want.
A 114 LSA would have a little bit more lope, but a 112 is probably what you'd ultimately want.
Do not forget about tuning.
Old Jun 19, 2007 | 06:09 PM
gmtechnician's Avatar
i thought that a 112 would have more lope than a 114?
Old Jun 19, 2007 | 06:47 PM
truckmann's Avatar
I believe it will. I think ChevyThunder17 was saying that the 114 lsa will have more lope than the 115 of the trucker cam, but a 112 will have even more. Which is probably what Jeff wants.
Old Jun 19, 2007 | 08:37 PM
Jeff12's Avatar
so what would be a good cam that has a 112 lsa
Old Jun 19, 2007 | 08:56 PM
nightrunner's Avatar
Mr. Obvious
either a 220/220 or a 224/224
the TSP 224R looks nice, same specs as a TR224 but a bit more lift
Old Jun 19, 2007 | 10:20 PM
truckmann's Avatar
Just remember if you are looking to save some money keep your eye on the classifieds.
