Cam, gear, and stall choice help
Cam choice for my Bronco LSX, I would be utilizing for off-road, sand dunes, and street driven. I want the best cam choice for my set up. Please provide cam specs, stall, gears etc. that would suit me the best for my purposes. I did have a 224/224 on my SS clone which worked perfect for that application, not sure if that cam will do for a 4X4 on 35's.
Vehicle: 1995 Bronco Motor: 6.0 LQ9 Transmission: 4l80e Transfer Case : NP245 Gears: 4:10? Stall: ? Cam: ? Tires: 35's |
218/224 cam, 278mm 3000rpm stall converter, 4.88 gears
Shorter duration if you're really using it for off road...
I would say a
-TSP 220/220 .600/.600 112 LSA, 1200-6200 RPM, 278mm 2800-3000 Stall, 4.88 Gears -TSP 216/220 .600/.600 112 LSA, 1400-6000 RPM, 278mm 2600-2800 Stall, 4.56 Gears The 216/220 Cam would be the smallest cam I would choose for a 6.0 and would be a better choice for Lowend Torque The 220/220 Cam is a great choice for a 6.0 and would be better suited for Mid HP and Torque and would be ideal for the dunes. |
