-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Cam Gear Question (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/cam-gear-question-538770/)
EscaTruck Jul 20, 2015 10:21 AM
Cam Gear Question
i have a 2007 saab 97x now... sold the escalade a while back
dod lifter number 6 went on me... i need to know if the cam gear is 3 bolt or 1 bolt.. i want to do a dod delete... please let me know! motor is the same on the trailblazer 5.3 aswell... engine code: LH6
please lmk want to order the right parts
thanks
Jordan
JL Sargent Jul 20, 2015 10:46 AM
If they are DOD engines then they are gen IV engines and likely with 1 bolt cams right now. You could go with a 3 bolt cam, just make sure you get the correct cam sprocket for your engine(s).
EscaTruck Jul 20, 2015 10:55 AM
thanks for the reply... i have seen an open lh6(not mine)... and i swear i saw a 3bolt cam gear... but i dunno i thought the single bolts were only vvti... but it is dod... the year is 2007 if that helps someone figure it out...
LS1TRUCKGUY Jul 20, 2015 11:01 AM
just buy a 3 bolt and a 1 bolt cam gear. return whichever you dont use. just make sure the 3 bolt cam gear is 4 pole 58x. all single bolt cam gears are 58x
FWIW my 2007 5.3L truck had a single bolt. it had DOD and was non vvt
JL Sargent Jul 20, 2015 11:42 AM
My 2007 1/2 was a 1 bolt but now its a 3 bolt. :drive:
