Cam card for L33 cam needed please
Have searched everywhere including calling GM tech line 1 866 453 4123 for cam specs of GM# 12583623 cam. Using it in a LC9 that I am removing DOD AFM from and seeing posts saying Dot to Dot timing does not work due to all LC9 crank keyways not cut the same as L33 cranks! Before closing up engine I would like to degree cam to see if cam is close but close to what ? Need intake opening at what degree BTDC, installed centerline, or any spec to verify proper timing. DO NOT want to tear out cam again to time to crank. THANK YOU
LVSTOGOFST2002
45
11-01-2005 02:27 PM
