-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   cam bearing question (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/cam-bearing-question-501496/)
greasemykey May 7, 2012 09:09 PM
so i got to looking at my cam bearings since my block has been torn down. they are showing more wear on one side than the other. my concern is that i need to line bore the cam. just wondering if thats normal or not.
dmelvin May 7, 2012 11:21 PM
It's normal on these motors to be discolored on the bottom side of the cam bearing.
greasemykey May 7, 2012 11:48 PM
i need to get a picture up here but that is good to hear. i was assuming that it had to do more with the load bearing side of the cam than a misalignment.
TXSZ66AVLANCHE May 8, 2012 05:36 AM
If you have the block torn down take it to have cam bearings changed, they are cheap.
greasemykey May 8, 2012 11:12 AM
its getting new bearings i was wondering if i needed a line bore
