Building an LQ9.....
So I decided the cheapest way for me to get my LQ9 is to build one, and I started my acquisition with the rotating assembly that I just bought from grippy. My question is this: how much of the 5.3 stuff can I use in the 6.0? I know I need a 6.0 block and 317 heads, but will everything else swap over? i.e. timing covers, oil pump, lifters, oil pan, flywheel, etc etc etc?
Yup, everything will interchange.
everything should interchange, but finding the LQ9 specific crank and rods can be a bit tough.
I took all the sensors, flywheel, replaced the oil pump but it was the same, pretty much everything off the 5.3 and put it on my LQ4.
Sweet...I already got the hard part done then, the LQ9 pistons, rods, and crank I just bought from grippy, so all I got left is a block and heads, then I can start building! Thanks all.
I gotta say
you got a nice deal 200 for the rotating ass just think... 695 for a 6.0 Iron block from sdpc and thats basically a brand new LQ9 short block for around 1000 bucks any thoughts on heads and cam choices? I like the idea of a radix on a H/C LQ9 after the truck already turned a 13 with the 5.3:eek2: :judge: |
pshht, I got you all beat. $2000 for a new 2004 crate LQ9 complete from injectors to oil pan, waterpump to flexplate with GM plugs still on the ends of the hoses. Ohh yeah, thats delivered to my door :D
I got hoed on the trans though. $750 for one that was taken out of a denali that was wrecked on delivery (7 mles). Came with the converter. No core :D sorry, i'm a bragging jerk :judge: |
I got hoed on the trans though. $750 for one that was taken out of a denali that was wrecked on delivery (7 mles). Came with the converter. No core :D sorry, i'm a bragging jerk :judge: :jest: :jest: :jest: OK good deal though:judge: |
For heads you might as well just get a nice built set from WCCH...might be a core charge I guess, but in the end you'll end up with some nice worked heads.
Id get the ones just like grippys with the 73cc chambers |
| All times are GMT -5. The time now is 07:07 AM. |
