Broken Manifold Bolts??
Old Jan 27, 2013 | 07:56 PM
kevins01silverado's Avatar
Registered User
so the nut should slide over the bolt then weld it?
Old Jan 27, 2013 | 08:06 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Use whatever you have laying around that you can make work. You'll be welding thru the center of the nut, onto the broken bolt.
Old Jan 28, 2013 | 05:52 PM
iregret's Avatar
Charlie Murphy!
I had to do this. Real simple to weld the nut on there. Chevy has a revised bolts available. I ended up replacing all of mine with the newer bigger bolts.
Old Jan 29, 2013 | 04:18 PM
RezinTexas's Avatar
I used the SS header studs on re-install. very clean.
ARP Header Stud Kit, LS1, LS6, 5.7L & 6.0L | WS6store.com
Old Jan 29, 2013 | 05:05 PM
WhiteChevy3's Avatar
My old 99 5.3L was the same way as yours. I just let it leak since I was building a 6L. If you are keeping the 5.3 for a while u can weld a nut on there and remove it. And get the bigger headed bolts as iregret mentioned, or a quick trip to fastenal will work too. Hell even my 07 lq4 had one of the bolts broke...
Old Jan 29, 2013 | 05:51 PM
Koots's Avatar
I was lucky enough to have 1 or 2 broken off with threads sticking out and 2 more that just fell out. my manifold was pretty warped though and i resurfaced it as best as I could with hand files and it's been leak free ever since.
Old Jan 29, 2013 | 06:29 PM
texasglock23's Avatar
I had zero threads...hope you are luckier than I was
Old Jan 29, 2013 | 09:06 PM
Registered User
the bolt is actually flush with the outside of the manifolds so im hoping when i pull the maifolds off i can just get them out with pliers or something and some good old pb blaster! also going to get some replacement bolts, you guys want a write up when i get these headers in with pictures?
Old Jan 30, 2013 | 06:14 PM
Koots's Avatar
PB Blaster is a good choice
It sounds like you may have it easy, but I would fix them ASAP so vibrations don't crack them off flush with the block.
Old Jan 30, 2013 | 06:19 PM
03sierraslt's Avatar
Unhook your battery and computer before you weld, its not common but I seen a PCM fired from not being unhooked and vehicle welded on last week. For a broken manifold bolt mind you.
