Which is better, H-pipe or X-pipe?
Hey guys i would like to know which flows better, an H-pipe or an X-pipe? Also are you guys H & X pipes custom jobs from the local shops or are they a piece that can be ordered? And if so where from? Thanks for any input you may have. :headbang:
Seems I read somewhere that an X-pipe is more efficient for balancing exhaust pulses...especially at the higher revs. I don't recall seeing any listed on any of the sponsors sites but Heddman and Dynomax both offer kits. Jegs sells em'. A H-pipe welded in by your muffler shop would probably be sufficient if it's no longer than a foot between the two pipes and no further back than 18" from your collectors.
Jeg's Kit
What I have been reading/hearing lately is that an X or H type pipe is really only enhancing on a system with equal length pipes. So with a truck's longer driver's side pipe, that's impossible to achieve. Has anyone seen any dyno results for one of these on a truck?
I know they work great on vette's, f-bodied, etc....cars. |
Hadn't thought about that
Originally Posted by rileyc8
Hey I'm glad u mentioned that, it does sorta make sense. It might be a good idea for me to run true duals with an X-pipe but with both pipes exiting on the passenger side. If nothing else it would be different. I might get angle cut pipes about 3" wide then have them come out at the corner of the rear passenger side. I'd get points for originallity anyways right? :rock:
like this? ;) http://s92490305.onlinehome.us//exhaust/exhaust22.jpg |
Exactly like that!
How's it sound? |
I would love to see some dyno info on X-pipe vs H-pipe or no crossover, because i was seriously thinking of doing an X-pipe my self.
Love that exhaust. You're a man with good taste. :cheers:
How's it sound? ASM Headers, no cats, x-pipe, and dual borla pro xs mufflers. |
I own have my own exhaust shop so i have had my exhaust just about any way you can think of.With no equalizer pipe truck runs like crap, ruff idle vibrates shudders when you get on it.With an H pipe its better than nothing it runs and drives good has good power.With an X pipe its the best,the most power and the best sound engine is real smooth.When the truck made 511/491 it had 2 1/2 super turbos,it has 2 1/2 flo-pros on it now i was suprised at how much i like them cruising around they have a really deep tone and you can hear the cam more at idle and not a lot of drone. :cheers:
