Any drag shocks?
Old Dec 31, 2004 | 12:25 AM
GrannySShifting's Avatar
Default Any drag shocks?
to fit these trucks?
Should I just dump the leaf springs and go coil over? 11.0s first pass out, need to work on the suspension
Old Dec 31, 2004 | 10:18 AM
hellbents10's Avatar
LS1Tech Sponsor
Have you tried cal-tracs yet???
1.51 60ft on 235/60R15 MT ETstreet radials.
TJ
Old Dec 31, 2004 | 10:39 AM
GREGGO's Avatar
What did I miss? I wanna hear more about these 11.0's. Is there another thread somewhere? BTW, someone used some HALS, but I don't have time to search it for you. Wife said it's time to go!!!!
Old Jan 2, 2005 | 12:22 PM
No completely stock suspension right now. What setup are yoru running and what does the caltracs replace?
Old Jan 2, 2005 | 03:59 PM
the cal tracs do not replace anything. what is your set up????
Old Jan 2, 2005 | 04:16 PM
lm7's Avatar
lm7
i believe its a customers setup . rcsb 2wd, cammed Lq4 stock headed th400 Procharged on spray stock suspension on ET drags....
Old Jan 3, 2005 | 12:12 AM
What he said well except its a completely stock longblock, stock cam/springs etc. Shifted at 6000, although it wants more rpm.. but stock springs are not pimp. Kept blowing 4L60E up, so T400 in it now.
Throwing blower cam/springs in it, then working on the suspension. Thats the gray area with me, not having fooled with drag setups with these trucks much yet, Im a torque arm car guy. Get that straight and in the 1.5s 60s or better where it should be... then in goes the real motor and up goes the boost
Old Jan 3, 2005 | 12:49 AM
Cal-tracs work great, and are an easy place to start for getting better launches.
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
Alco
Oct 4, 2015 06:58 AM
Slammed silverado
Sep 28, 2015 06:14 PM
