alternator output
Real quick Do I should stick with 190 or 200 even 250amp for my 2006 Silverado. Which is best one should I get one? I just want look for polish on alternator also. What cost it would be?
I use the 250amp. Been working great for awhile now. I use to have a big audio system but it definitly helps when all my efans are running etc.....
But like said, you wouldn't need anything that extreme unless needed.
http://www.powerbastards.com/default.asp
Check your glove box for these codes. I'm only listing the GM RPO's for alternators 100 amp or higher here.
8A7, KG8 - 130 amp
8A3, KW2 - 124 amp
8A5, 8C0, K98, KG9 - 140 amp
8C6, KG3 - 145 amp
8C7, KG4, KG5 - 150 amp
8W5, 8X5, K61, K62, K65 - 105 amp
8Z3, 8Z4, K60 - 100 amp
K09 - 120 amp
K63 - 110 amp
KG7 - 125 amp
KW1 - 160 amp
KW3 - 135 amp
KW7 - 170 amp
KW9 - 190 amp
KYU - 200 amp
8A7, KG8 - 130 amp
8A3, KW2 - 124 amp
8C6, KG3 - 145 amp
K09 - 120 amp
K63 - 110 amp
KG7 - 125 amp
KW1 - 160 amp
KW3 - 135 amp
KW7 - 170 amp
KW9 - 190 amp
KYU - 200 amp
lxcoupe
Oct 26, 2015 10:13 AM
drummer0415
11
Oct 24, 2015 08:16 PM
