79lb injectors?
Old Nov 24, 2007 | 02:23 PM
fullthrottledan's Avatar
Default 79lb injectors?
has anyone had a chance to try these new injectors from racetronix yet? I need more than 60s but not sure if i wanna step up to 96s and run a driver box. Is there any cons to running the driver box? hard to tune?
http://www.racetronix.com/01D129xFM.html
Dan
Old Nov 24, 2007 | 04:25 PM
8ALTNG's Avatar
Ask Slowhawk about the driver box setup. He did it on mine and I love it, but I wasnt the one who spliced all the wires and had to tune them. He could give you a good idea about how they are. From my stand point I love them and so does every gas station I drive by.
Old Nov 24, 2007 | 07:13 PM
quicksilverado's Avatar
Check in the FI section on ls1tech. There are a few guys running them already.
Old Nov 24, 2007 | 11:05 PM
Casey2323's Avatar
You need more then 60s? its your IDC crazy high ? I see more and more people Brag on what exactly 60s will support.... I think with enough -8 line dual pumps and a Boost sensitive Regulator people have made over 1000hp...
Old Nov 25, 2007 | 04:37 AM
Rhino79's Avatar
9 Second Club
Those 79lb injectors are rated at 43.5 psi, so at 58 psi they are actually about 91lb. 60's should be good to 700-800ish rwhp with the right pump setup.
Old Nov 25, 2007 | 02:57 PM
vanillagorilla's Avatar
Low speed and idle tuning will be difficult with that big of a high impeadence injector. I've heard a number of stories where guys go from 60's or 72's to 83's or 96's with the accelleronics box and it actually has better driveability and idle quality.
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
