-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   69 327 hp? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/69-327-hp-513900/)
04silvyhotrod Feb 6, 2013 08:53 PM
69 327 hp?
Well I built this motor 2 years ago and never did have it on a dyno. Its been in my mud truck ever since. Here is what is done to it, 69 Marine Block(Higher Nickel Block), Steel Crank, Lunati Bracket Master 2 cam, Speed Pro .60 Flat Top Pistons(2 Valve Reliefs), Chromoly Rings, TRW Crank and Rod bearings, Zoom Double Roller Timing Chain, 63 Model 461x heads(Fuelie Heads), Screw In Studs, Comp Cams Roller Tip Rockers, Heavy Duty Valve Springs, Ported and Polished a bit, 1.54,1.94 Stainless Steel Valves, Offenhauser 360 intake(ported to match the heads), edelbrock 750 carb, Longtube Headers, Accel Distributor. Info on the cam, Duration is 246° at .050". LSA is 108°. Lift is .515". I have maybe $700 in the whole build. Found the block, crank, rods, and heads at a junkyard and bought them for $75 and went from there. It turns my 38s over easy with the sm465 4 speed and 5.13 gears. And it like to be reved way up.
Suburbazine Feb 7, 2013 01:40 AM
You probably have lots and lots.
Get it on a dyno, you've got a lot of custom variables for someone to give you even a rough guess.
04silvyhotrod Feb 7, 2013 05:30 PM
Yea I need to get it on a dyno because I would like to know what its hp is. But it runs good in my truck. I would like to drop it in a car or truck and have a good street runner.
RacinRust Feb 7, 2013 06:18 PM
Those 327's were great little engines. The production ran from "62 to "69. Any where from 8.5 to 1 compression @ 235 HP all the way to 11.5 to 1 @ 375 HP. Of course the higher HP version were in the vette with the larger cylinder heads and FI, or if a Holley carb was your choice 365 was the number. The 4" bore, 3.25 stroke and a 5.7 rod length was a good combination for a realiable high revving engine. Is yours a small journal 327 or a large journal ?
04silvyhotrod Feb 7, 2013 08:02 PM
Its a large journal and the heads came off the old 63 vette. There one of the best double humps you can get and there worked some.
