6.0L is finally in
Originally Posted by BADMOFO
This motor had a DBW throttle body, and I stuck my cable tb back on, but the bosses in the intake didn't have the threaded bolts (not all of them anyway) where the throttle wire bracket bolts down. Does anyone know how to get those in there, or if you can even order them. I guess they are knurled and just tap in ???? Does anyone know what I'm talking about?
Cuz I AM a BADMOFO
Originally Posted by 5.3 racer
cut them out of a "donor" manifold, like you said they're knurled and tap right in. make sure you countersink the existing boss otherwise they'll stick up a little bit. i've seen them called "nut-set's" but have yet to locate them seperately.
You can't see it as it is under the cover, and it kinda gives it that back yard feel, but I gotta get it right. I'm driving it every day, as it wasn't even down for a day, but I still need to "touch it up" a little. What's up with this Crank Relearn that everyone is talking about?? I'm gonna try to get the SES light turned off (due to no EGR) early this week, should I get the Crank Relearn thing done as well??
Congrats on the swap. Im fixing to do the exact swap on Memorial day weekend. My truck is a 2001 5.3 and im installing a 2005 h2 hummer 6.0. So i can absolutely use my cable on this intake instead of the electric throttle that is supposed to be used on the 05 models? Thanks Gary
