6.0 swap. help me get the engine to start fellas..
ok guys, as you see i dont have to many post, i use the search button like crazy to find most of my answers.
that being said, heres the lowdown. just did a lq9 swap in 2000 rcsb. original motor was 5.3.
the engine has a 228/228 114lsa cam - other than that the bottom end is stock. heads are basiclly stock besides dual springs.
i have everything hooked up that i know of besides 02s.
i read 1slowz71's thread about his last motor swap issues,and my truck is doing basically the same thing- the motor will turn over, but acts like it is only trying to start on 2 cylinders. it will puff a little white smoke out every couple of times. i put a light on it to see if it was getting spark and it is, but when i pull the plug its not wet. im going to try and go get a fuel psi guage today to see what my pressure is like. but i ould think i have fuel because one of my fittings on the rail was loose and started leaking.
the first thing i need to start with is the grounds. i have read plenty of threads on this, but im just not understanding fully.
to start, how many grounds (from the harness only) are there behind the passenger side head? i only see one but everybody says theres 2?
on to the second issue. once i changed the injectors 2 of them started leaking from the top of the injector. can i buy new Orings , or do i have to buy all new injectors?
biggest issue, the oil pressure is not moving on my guage, i also pulled the filler neck to see if i could see oil in there and didnt really seee any. any ideas?
You can get new o-rings at autozone/napa/advanced etc.
...obvious question, but did you put oil in it? Is there a big puddle of oil under the truck from a forgotten drain plug or filter?
Did you reuse the oil sending unit from your old engine? Take a valve cover off and turn it over a few times and see if you get any oil....it may make a mess so be warned.
Did you pull the pan before you swapped the engine in? Oil pickup may be clogged...
