Cam Gear Question
Cam Gear Question
i have a 2007 saab 97x now... sold the escalade a while back
dod lifter number 6 went on me... i need to know if the cam gear is 3 bolt or 1 bolt.. i want to do a dod delete... please let me know! motor is the same on the trailblazer 5.3 aswell... engine code: LH6
please lmk want to order the right parts
thanks
Jordan
thanks
Jordan
If they are DOD engines then they are gen IV engines and likely with 1 bolt cams right now. You could go with a 3 bolt cam, just make sure you get the correct cam sprocket for your engine(s).
thanks for the reply... i have seen an open lh6(not mine)... and i swear i saw a 3bolt cam gear... but i dunno i thought the single bolts were only vvti... but it is dod... the year is 2007 if that helps someone figure it out...
Castro45
24
07-31-2015 07:13 PM
bbowerman
07-26-2015 10:57 PM
