-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   5.3 vs 6.0 starter (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/5-3-vs-6-0-starter-346570/)
Formulized94 Aug 13, 2005 01:36 AM
5.3 vs 6.0 starter
what is the difference between the 2 starters? they have a different part number and I need to get a starter, unless a 5.7ls1 starter will work.
TheRealSS Aug 13, 2005 02:02 AM
no clue...
do they look different, have you put them side by side?
gonzo 6.2 Aug 13, 2005 10:28 AM
The 6.0 with a 4L80 may have a different starter than a 6.0 with a 4L60e because the flexplate sets in further.I used my 5.3 starter on my 6.0,check a 6.0 part number from a SS or VHO or Denali.
TJ Aug 14, 2005 09:03 PM
AFAIK, they are all the same.
there is a short and a long bolt version tho.
worst case.... you would have to go to the dealer and buy one short bolt or one long bolt.
good luck.
i have a 2004 vette starter on my 2004 6.0 and its cranking fine.
