-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   5.3 turbo head choices? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/5-3-turbo-head-choices-521522/)
99MedBlueBird Aug 30, 2013 07:32 PM
Okay guys, I'm having a little trouble here. I'm building a 5.3 lm7.
First of all. Here is my setup.
Eagle CRS6125O3D 1.125 length .927 wrist pin
Wiseco k474m965 -2cc flat top pistons .927 wrist pin. 3.800 bore
KING main and rod bearings
Wiseco 3805HF rings
Master power t76 1.0ar
I'm trying to decide what head I want to go with. According to wiseco, a 61cc head will give me 10.4:1 compression ratio. I really don't want to run a turbo on that high of a CR. I'm not quite sure what head to use. I was thinking 799 heads (64cc) with a thicker gasket. Any ideas what head I should use? I want to be around 9.7-10.0:1 CR. opinions are greatly appreciated
batboy Aug 30, 2013 08:02 PM
Either 243 or 799 heads at 64cc with GM MLS gaskets will be at or a tad less than 10:1.
Blackpanther99 Sep 1, 2013 12:33 PM
799s will get the job done with MLS head gaskets.
