5.3 Questions
Old Aug 26, 2007 | 05:49 PM
usarmyman's Avatar
Default 5.3 Questions
Ok so here goes. I know that the 4.8 and the 5.3 have the bame bore, so in theory I could use 4.8 Flat top pistons in my 5.3. So what are the advantages/disadvantages to doing this. Would it be worth the money to get that little bit higher CR? Or will it just be better to leave well enough alone?
Thanks, Josh
Old Aug 26, 2007 | 05:51 PM
nightrunner's Avatar
Mr. Obvious
i beleive that i read the 4.8 piston has a different wrist pin height or something, anyways its meant for the 4.8 rod
Old Aug 26, 2007 | 05:54 PM
usarmyman's Avatar
So it wont work in a 5.3, damn there went my hopes and dreams
Old Aug 26, 2007 | 05:57 PM
Mr. Obvious
id let some one that knows for sure chime in but i dont think they will
Old Aug 26, 2007 | 10:35 PM
53bowtie's Avatar
i dont think they will either....not sure though but i think that when you make a 4.8 a 5.3 you have to change the crank, rods, and pistons so it makes sense you would have to going opposite.....also i know the crank is diff. for a 5.3 than a 4.8 so you might have clearance issues with the flat top piston as oppose to the dish piston if you use the 5.3 crank....dont know from personal experience though....
Old Aug 26, 2007 | 11:53 PM
06sierra5.3's Avatar
there are factory 5.3 flat tops.
Old Aug 27, 2007 | 05:35 PM
Mr. Obvious
from the L33, i forgot about those, but they are probably few and far between
Old Aug 27, 2007 | 06:46 PM
usarmyman's Avatar
If I did could find some L33 pistons, would it be a worthy upgrade. It will raise my CR from 9.5-1 to 9.9-1. Or should I just shave the heads and get that much or even more.
Old Aug 27, 2007 | 07:31 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
If you go flat top pistons you will also need 64 cc heads to bring CR down to 9.9:1
Old Aug 27, 2007 | 10:25 PM
Z28RPM's Avatar
11 Second Club
Read this it will tell u everything!
http://www.automotiverebuilder.com/ar/eb040538.htm
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
