Killtank |
05-25-2010 10:49 AM |
5.3 knock sensor replacement. HOLY CRAP!
2 Attachment(s)
So yesterday I decided to knock out the knock sensors and get it out of the way. I pulled the intake manifold off and was amazed to find half of Texas under it. So now I can see why my knock sensors where throwing a code.
Attachment 142007
So I took a shop vac, cleaned as much of it off as possible and began removing the knock sensors. The front came out no problem. The rear had to be drilled and extracted. :cry: . 2 beers later and after taking gm's name in vein I started to re assemble and install the new sensors (which was not a problem). I also took a bead of high temp silicone and drew a moon shape around the opening of the back knock sensor with the opening towards the rear of the block. (this was in a bulletin for replacing the knock sensor). I also Took the foam blocks out of the intake manifold (as shown below. The white arrow shows the foam block and black shows the block already removed) This would allow drainage of water and the rest of texas from collecting back up on the block.
Attachment 142008
With everything back together I cranked it up and surprise! no more trouble code! Now I shall think twice before going through mud.
