5.3 head replacement
Old May 19, 2012 | 08:10 PM
red3232's Avatar
Registered User
Default 5.3 head replacement
I have the castech heads and am in the middle of replacing them. I made a rookie mistake and on re-installation i forgot the dowel pins. So no I'm going to have to pull it apart. The question I have is i have torqued the bolts and was wondering if I needed to replace them. The engine is still in pieces. I am lucky that I caught it early but still wanting to save as much money as possible. Thanks yall
Old May 19, 2012 | 08:17 PM
probuilder1's Avatar
If they are factory bolts then yes, if they are ARP then you can reuse them.
Old May 19, 2012 | 08:19 PM
red3232's Avatar
Registered User
They are Fel-pro
Old May 19, 2012 | 09:09 PM
Then you can't reuse them
Old May 19, 2012 | 09:31 PM
lady3bglover's Avatar
<< ha, ignorant me... never thought about using Fel-pro head bolts. Never knew they made them. I've always gone with the flow and bought ARP.
Old May 22, 2012 | 03:28 AM
DR132's Avatar
there's a good reason why people recommend ARP bolts and studs...
Old May 22, 2012 | 05:52 AM
iamkeniff's Avatar
Arp is double the cost but issues like that or warped head keeps me from spending the money on head bolts again or worse 3-4+ times
Old May 22, 2012 | 06:04 AM
Honestly, I had no idea. With the upgrades to the stock 5.3 heads, swap to the Patriot Performance heads on the 5.3 and the new 6.0/Ls6 heads are all ARP. So why would I know differently?
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
sauldgold
Jul 23, 2015 02:15 PM
