454 BBC 500hp!!!!!
Old Dec 2, 2008 | 10:12 AM
fotoboy2's Avatar
Registered User
a good set of oval port heads will out perform squareport heads because of the port velocity is much better at the level you want to perform at. Talk to any grassroots racer and he will tell you the same. Save your money for rect port for big ci and high compression engines.
Old Dec 3, 2008 | 01:06 PM
blueflamed03's Avatar
AMEN!
Keep it to 10:1, a great set of 781's would be the best bang for the buck. A solid, or solid roller cam. Roller if you can afford it, if not, just a solid will suffice. getting 500HP out of a 460 is pretty easy.
Old Dec 4, 2008 | 05:32 PM
1NKRED1BLE's Avatar
is there anyway you can the diffrence between the cam, so far somebody has suggested a roller cam, solid cam, and now the hydraulic, im cofused as to which one does what
Old Dec 5, 2008 | 08:52 AM
solid roiler, will have a fast ramp rate, and be way more accurate and have more lift. Roller lifters.But, more expensive. The cheapest route is a hydraulic...adjustable, not as accurate, less power. The middle of the road, is the solid. Like the solid cam in the Chevy 302's back in the day.
I built many smallblocks, used hydraulics. Ran a solid ONE time, and will never go back to hydraulic..way more power than the hydraulic. Now if I had the money, I would have done solid roller...just couldn't afford the setup at the time.
Solids are not much more than a hydraulic either...
Old Dec 6, 2008 | 12:16 AM
1NKRED1BLE's Avatar
hey ed quick question anyway you can quickly explain the diffrences between cams? i just basically want to build a street ride 496 and have a minimum of 500hp
Old Dec 6, 2008 | 12:27 AM
1NKRED1BLE's Avatar
thanks flame, so basically solid rollers are a little bit more expensive but the best ones?
Old Dec 8, 2008 | 10:19 AM
correct. But want better, without the cost, just a simple solid cam will suffice.
Old Dec 9, 2008 | 03:03 AM
1NKRED1BLE's Avatar
definitely dont want to adjust lash all the time, i dont know even know what that means.
Old Dec 9, 2008 | 11:01 AM
you won't....get some good polylocks, adjust them, set it and go...maybe adjust 2-3 times a year...
Old Dec 21, 2008 | 10:24 PM
xx_ED_xx's Avatar
yeah go with a solid cam .... NOT
Since I actually own a big block
but I digress
1NKRED1BLE - if you actually do something with the car let us know
