-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   The 40-45 and 60-70 mph vibration (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/40-45-60-70-mph-vibration-84878/)
RED2K Jul 6, 2003 09:26 PM
How do you get rid of this? I have heard others have this problem as well. I had all my tires balanced twice and they are all good. There are no bent rims. they did this with my 295/50's and seem a bit worse with the 275/60's. Is the drive shafts on these balanced correctly?
Vortech5300 Jul 6, 2003 10:44 PM
Re: The 40-45 and 60-70 mph vibration
Is the truck lowered? If it is, it MAY need to have the pinion angle adjusted. I just did a 4" drop and the pinion angle changed quite a bit. Can you feel it in the seat or in the steering wheel? Can be a lot of things.
BlownChevy Jul 6, 2003 10:51 PM
I agree with you if the truck is lowered...........
RED2K Jul 6, 2003 11:09 PM
Two inch drop in back is it. Didnt think about that, thanks
hodgeee Jul 7, 2003 04:24 AM
Hey, I've noticed the same thing on my truck. I feel it at the same speeds. I was just going to go tommorow and have them rebalance the tires. I feel it right in the steering wheel. It actually jiggles my watch. I'm running 275/45/20's. I also noticed that I can't hardly feel it when it is cool outside though, so I am confused as hell.
