2nd vs 3rd gear pull ?
Old Apr 13, 2004 | 02:55 PM
quicksilverado's Avatar
Default 2nd vs 3rd gear pull ?
What is the difference between a 2nd gear versus a 3rd gear pull on the dyno. I know its best to get as close as possible to a 1-1 ratio, but I've noticed that 3rd gear pulls seem to yield higher #s.
Old Apr 13, 2004 | 03:28 PM
Deckhand's Avatar
3rd gear is a 1:1 ratio, so i would assume it would dyno correctly in 3rd
Old Apr 13, 2004 | 05:25 PM
F8L Z71's Avatar
Some dyno's require you to dyno in 2nd gear for autos and 3rd for sticks. Just depends on how that dyno works.
Old Apr 13, 2004 | 06:39 PM
My #s were 301 rwhp & 326 rwtq in 2nd. What would that equate to in 3rd.
Old Apr 13, 2004 | 06:56 PM
TRW427SS's Avatar
I've seen several back to back 2nd gear versus 3rd gear pulls and 3rd gear pulls always gained 20 rwhp and something over 20+ rwtq.
Old Apr 13, 2004 | 07:20 PM
F8L Z71's Avatar
Like I said though. Depends on the settins on the dyno. If it is set up for second gear pulls then going on another dyno and doing a 3rd gear pull wont make you gain more HP.
Old Apr 13, 2004 | 07:24 PM
let me ask you somthing the last time I dynod I was pretty much stock so I
did it in second gear but the dyno was set up for 3rd gear so what real gain should i expect
I was at 250hp and276tq
Old Apr 14, 2004 | 11:16 AM
LOW2000's Avatar
Most of the time, unless you have programming to raise your speed limiter, if you tried to dyno in 3rd, you'd only get to about 3000rpm before the truck shut down because of the speed cutoff.
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
Oobray
Jun 13, 2022 03:38 AM
1slwgto
Aug 16, 2015 06:40 PM
lxcoupe
Jul 14, 2015 10:14 PM
