-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   2500hd overheating (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/2500hd-overheating-538636/)
ullose272 Jul 12, 2015 03:57 PM
2500hd overheating
ive got a 2500hd with 05+efans that is overheating sometimes. its fine around town, but when i was on a road trip it was about 105 out and cruising at about 85 mph it would get up to about 235 with the a/c on pulling grades (anytime rpms were up really) i didnt notice this at all last summer. now we just picked up a camper the weighs about 6000 lbs and it will get hot 235-240 when pulling grades and it was only 75 out. i have a larger trans cooler as well and it stays about 125 until engine temp gets hot then it gets up to about 200.
i replaced the thermostat and the temp sensor. water pump is about a year or so old NAPA unit. only thing i can thing of really is maybe the radiator is plugged? or partially? i tow alot in the winter and never overheats but its also below freezing most of the time.
any ideas/suggestions? ive cleaned the fins of the radiator and condenser, deffinatly air traveling through. it will cool down if i pull over and idle for about 5 min but heats back up til im off the grade
GMCtrk Jul 12, 2015 04:18 PM
Sounds like a radiator problem to me, since it's doing it at speed.
It could be internally plugged up if you confirmed that the front is not full of debris/trash (they get like that over time).
The other considering is that your thermostat isn't working properly.
ullose272 Jul 12, 2015 05:24 PM
ya first thought was thermostat, thats why i replaced it. and it was the original so i figured what the heck. but no dice.
GMCtrk Jul 12, 2015 05:26 PM
Water pump could be bad
terravast4 Jul 12, 2015 09:54 PM
I have an 05 and every now and then mine runs hot. I popped the hood one day and found only one fan running...it only happens every once in a while though.
txsilverc6 Jul 20, 2016 04:45 PM
any luck?
FFDP Jul 20, 2016 09:17 PM
After a whole year, I'd hope so lol.
ullose272 Jul 23, 2016 05:55 AM
Originally Posted by txsilverc6 (Post 5370908)
any luck?
I replaced the radiator with an aluminum one that is 1/4" thicker. But ive been deployed til now so ill probably know here soon. I think im going to throw on a flowcooler water pump and 160 tstat as well here soon.
ullose272 Aug 5, 2016 02:05 PM
its no longer overheating
