2015 GMC Sierra Whippled/Meth 6.2L opinion on repair
Got a 2015 GMC Sierra 1500 4X4 with 6.2L and max trailer package bought new.
Racing shop installed Whipple, cam, & long tubes at 20,000 miles in 07/2015 then BDS lift/35" tires, more boost and meth in 07/2016. Torque convertor failed leading to trans failure so Circle D pro series TC and new stock trans went in 01/2018.
Now engine has obvious valvetrain malfunction...
https://www.dropbox.com/s/26zsqwwwtz...netap.m4v?dl=0
Waiting on oil analysis and oil filter inspection to speculate on extent of damage.
So....if a engine rebuild is required should we keep as is, remove meth, lower boost and get some reliability? Or stroke? Contemplating repairing and selling for a diesel. The truck is fun but it's my DD and unreliability is no bueno.
the duke35 (05-03-2018)
Twice, check engine light came on and disappeared after several key starts. Went by auto parts starts to read with scanner...they said multiple codes that related to exhaust (I have LT with no cats). I should have got the actual code numbers.
Post them up. Could be o2 stuck rich due to exh valve/lifter/pushrod issue. Is start with pulling the driver side valve cover off and check for loose pushrods, busted rockers, cracked springs.
the duke35 (05-05-2018)
Hoping to get them to fix and then maybe get a second opinion on tune. Shop is definitely known and reputable, but not perfect (blown fuse due to improper wiring of boost a pump left my other modded truck on side of road and this truck came back from new tranny install with an exhaust clamp at y pipe expansion joint never tightened). Maybe the small builds are rushed or performed by less experience staff. IDK.
oil analysis back
Shop says there's metal in oil filter. Here's the oil analysis. Won't have the valve covers off and motor inspected for another 30 days....
https://www.performancetrucks.net/fo...1&d=1529676457
