2010 Tahoe engine swap any ideas!!!!!!
i have a 2010 tahoe lt i would like to something that has at least 500 HP and Reliable and not going to tear up all the time something that not going to kill the pocket have about n 8000 to spend any ideas
Basic 5.3 with a used Magnusson/Whipple or Torquestorm supercharger.
Do a AFM/VVT delete and add a blower. 450-500hp easy.
Or 6.2 swap with a camshaft/long tubes and be well over 450+ crank horsepower. Then remember you need a new rear locker because the G80 will probably explode with rolling burnouts and hard launches. |
Are 2010s still 10b out back?
id can that fucker ASAP if youre lucky and have a 5.3 truck you have the 6 speed: find a good tuner for it or it'll die a quick one behind a turned up *anything* |
Whatever way you go to add more power, budget in for a 14-bolt semi-floater out of a RWD Yukon Denali or Escalade, they have 3.42 gears. Do not take Ebay seller's word for it either, make them confirm 14-bolts and not 10 if you go that route. AWD trucks have 10-bolts.
