2007 Tahoe.. Bad sending unit, Replace the whole pump?
As the title states I've got a 07 tahoe with a bad sending unit, throwing a code for the unit and the gas gauge is all over the place. I'm going to try and tackle this myself (Does anybody know of any good write ups?) but was wondering if I should just change the 80 sensor/sending unit or go for the whole thing while I'm in there? 88k miles on the clock.
For those who have done this how hard is it WITHOUT a lift?
Since you're dropping the tank, replace EVERYTHING. Since your pump still works, you should run the tank as empty as you can comfortably go. You'll need a floor jack and a furniture dolly to roll the tank out from under the truck. The truck should have about 2' of clearance from the ground to the running board/frame (whichever is lower) on jackstands. If your floor jack is low enough, put it under the furniture dolly so you can simply drop the tank onto the dolly to roll it out.
Replace the pump with an A/C Delco pump, not the shitty chinese Airtex option.
PS: Difficulty is inversely dependent on your determination. Get a Haynes manual or purchase an ALLDATA single vehicle subscription as they will help immensely.
Is the AC delco unit I can buy at autozone the same as the ac delco (OEM)unit I buy at the dealership (It is significantly less).
Do you have any opinions on the hatch method? Requires no dropping of the tank, and allows access if I screw something up.
How are AC delco and Delphi still related? Google it 10 times and youll get 10 different answers. Are the delphi units any good they run about 100 dollars cheaper.
THanks
Owen
Thanks so much. Couple follow up questions:
THanks
Owen
THanks
Owen
if its the same part number, its the same part!
not sure about the other method, but Ive drop these tanks on about 10 suvs already all the way back to the OBBS. its 2 bolts on the straps, and replace the entire sending unit so you do the job once. takes me about 2hrs if that.
