HELP.. Truck will not start after 5.3 swap..
Okay, trucks a 02 V6 Silvy, 5.3 is from 02 as well, PCM is from a 02 GMC. I changed the VIN, disabled VATS, and flashed a 5.3 tune into it, still no fire.... All 144 grounds are hooked up, crank sensor, cam sensor, etc.... I even took the fuse box from a 5.3 truck and swapped em and still nothing. Im a newb at tuning, so bare with me. This is getting really frustrating, and i dont know where to go from here. Any help is appreciated. Thanks, Eric.
Well I will tell you that you could have dealership load a tune and relink everything, when my truck was turbo charged. I went back to NA I had the dealership reload a 5.3 tune, I saved it on HP tuners before I put it back to stock and then when I put everything back I loaded the tune and it worked perfect I asked him at the time he said all he needed is a VIN# and about the same year with the motor you want to use, just look on autotrader for VIN's or the vehicle you got the engine from!
cams 98 silverado
07-31-2015 07:36 AM
