2006 Vortec max
I have a 2006 Silverado Vortec Max. Does anyone know what i have from factory. Like, heads-L92?, rear end 4l70?, I know it has 4:10 gears. Lt has a LQ9 6.0 L, is that ALUMINUM block?
VORTEC MAX PACKAGE: includes (LQ9) Engine, Vortec high-output 6000 V8 with "VortecMax" engine cover, (M70) Transmission, 4-speed automatic, super duty, (GT5) Rear axle, 4.10 ratio (includes (GT4) Rear axle,(G80) Differential, locking, heavy-duty, rear, (ZX3) Suspension Package, Ride-Control, (KC4) Cooling, external engine oil cooler, (KNP) Cooling, external transmission oil cooler, auxiliary, and (Z82) Trailering equipment, heavy-duty (NHT) |
Heads: 317
Trans: 4l65e Rear: 14b SF 9.5" Block: LQ9 (iron) The aluminum block 6.0 is the LS2 (in the TBSS). The LQ4 and LQ9 truck engines are iron blocks. |
M70 rpo should be 4l70
isnt the only difference an input speed sensor?
Originally Posted by Atomic
(Post 4429802)
Info - New Product Announcement - 4L70-E (M70) Automatic Transmission #05-07-30-026 - (Oct 7, 2005) 2006 Chevrolet Silverado, TrailBlazer SS 2006 GMC Sierra with 4L70-E Automatic Transmission (RPO M70) General Motors Powertrain required a version of a current production rear wheel drive transmission capable of handling higher torque and horsepower without going to a larger size transmission. As a result, the 4L70-E was created. Very much like the 4L65-E, the 4L70-E shares many of the same components and adding premium materials and additional manufacturing processes, the 4L70-E is capable of handling up to 400 horsepower and 430 foot-pounds of torque. It is also capable of increasing shift speeds up to 6000 rpm. The 4L70-E will be first introduced in some 2006 mid-size sport utilities and full-size pickups. The 4L70-E will be identified as RPO M70. The M70 will use the large 300 mm (101K or 112K) torque converter. Some M70 models will be the first 4L60 series transmissions to receive the new input speed sensor (ISS) . Below are the 2006 4L70-E applications and models: • Sport Utility 4L70-E models with ISS: SKD/TKD • Full-Size Pickup 4L70-E models: CMD, CWD & KMD Important: The following graphic and table describe only the essential components that make up the M70 transmission model and will not identify all parts. The following identifies the 4L70-E (M70) components and the components it shares with the 4L65-E (M32) transmission. Item Number Part Description ID Feature RPO M32 RPO M70 1 300 mm/112K Torque converter (1) • Identification code label affixed to the convert cover • Outer diameter & lug size X X 2 5-Pinion input carrier Asm. (662) Number of pinion gears X X 3 7-Plate 3-4 Clutch Asm. (7 friction, 6 steel plates) • Number of friction plates • Steel & apply plates have "HD" stamp • Friction plates have Identification stripe X X 4 5-Pinion Reaction Carrier Asm. (681) Number of pinion gears X X 5 Reaction Internal Gear Asm. (684) 3 machined grooves X 6 Output Shaft (687) One identification band X 7 HD Low and Reverse Roller Clutch Asm. Bronze clad cage X X 8 Input Sun Gear and Forward Sprag Asm (642) Paint marking X X 9 Input Turbine Shaft One identification band X X 10 Stator Shaft Darken splines X X Refer to the appropriate SI section for additional repair, diagnosis or description information. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION © Copyright General Motors Corporation. All Rights Reserved. |
Good info, thanks for posting.
| All times are GMT -5. The time now is 08:50 AM. |
