2000 Sierra 5.3 Mod Suggestions - Help
Hey Everyone!
I just joined this forum today and spend about an hour looking through it before I joined, lots of good info here! I am looking for suggestions on my 2000 GMC Sierra Ext Cab 5.3 4WD truck! I use the truck to pull a boat in the summer months and just as a truck the rest of the year. I am getting ready to put on some Long Tube Headers and a free flowing Exhaust System, I already have a CAI. Is there anything else I could do without spending huge money that would net me some good HP and TQ gains?? Thanks to everyone in advance that helps out |
Intake and a tune. Maybe a hand held tuner so you can adjust to when you pull that big ole boat compared to cruising around. btw Welcome!:cheers:
Originally Posted by Killtank
(Post 4485017)
correct me if I am wrong but I believe the Corvette servo increases hold pressure for 1/2 shift. Makes trans shift better/faster. Not a shift kit, but makes a more positive shift. Well worth the $15 and very easy to do.
Originally Posted by Suddog
(Post 4485744)
Thanks |
Just search it on ebay,or look through the classified's here,welcome :)
Also what gears do you have??? It may be worth doing a gear swap as well .. |
(Post 4485744)
Originally Posted by andrew383
(Post 4486549)
(Post 4486676)
Dead on brotha, Very easy install if your good with a flathead.
Originally Posted by Yukoncole
(Post 4487031)
How hard is the Transgo Shift kit to install??
I'd throw a cam in there if you're looking for some solid gains that you can feel and hear. If you want to stick with the stock torque converter, go with a cam like the one I have listed in my sig. If you don't mind upping the stall speed of the torque converter, maybe get a 212/218, 2600 converter, and you'll still be able to retain your towing capabilities ;) |
