08 sierra 4.8 intake manifold improvement over 99 5.3?
They are worth getting if you can pick them up for the right price. Yes they can add power to your engine, but you will have a couple of hurdles to clear to get everything working. As far as I’m aware, the newer 5.3’s have flat-top pistons, so unless you have the heads milled to get the compression back up, it will be counter-productive. You will need to factor in a cable operated 90mm throttle-body or run a 90mm to 78mm adapter to use your current unit. The fuel rails on the ’08 model intake are set up for a returnless system, whereas yours are return style and you would need to address this as well, but there are solutions to everything one of the hurdles I just mentioned.
