06 LQ9 Improvement
Good Morning/Afternoon/Evening :wavey:
I am a new member in this great forums and I am looking for some help with regards to improving my LQ9 performance. What I have is a 2-doors 2010 GMC Sierra + LQ9 swap + Comp Cam + PRC Cylinder Heads & CNC Ported + Pacesetter LT + Corsa Sport Catback + MSD Wires (Soon) The intake filter and intak manifold are the stock ones. I have two choices and I need to know which one is more effecient and will give me the better performance with improvement in fuel economy. Currently, fuel consumption is crazy I hardly can reach 460Km with one tank. So, the choices of improvement are: 1- Install LS3 Intake manifold with LS3 throttle 2- Install AFE SI Air intake + Throttle Spacer Which one do you recommend? and is there any other better way to improve the performance and air intake? Thank you guys in advance :thumb: |
LS3 intake parts wont fit your truck. They have different shaped intake ports on the cylinder heads.
Throttle body spacers are some kind of sick joke... dont waste your time. If you are running the 78mm intake that came on the LQ9 you would get more power out of the 87mm intake that came on your 5.3. |
(Post 5227541)
Throttle body spacers are some kind of sick joke... dont waste your time. If you are running the 78mm intake that came on teh LQ9 you would get more power out of the 87mm intake that came on your 5.3. |
Originally Posted by NipRing
(Post 5227545)
Spacers
(Post 5227541)
Throttle body spacers are some kind of sick joke... dont waste your time. If you are running the 78mm intake that came on the LQ9 you would get more power out of the 87mm intake that came on your 5.3. few articles about the throttle body spacer for vortec enginers. As you said, its a joke and waste of money. With regards to the 5.3 intake, at the time I purshased the new 6.0 engine the mechanic who did the swap told me that the intake mainfold of the 5.3 won't fit on the 6.0 and he guaranteed that, so I had to spend 400 dollars to by a new stock intake for it. However, I still have the 5.3 intake manifold at home. Thank you for your help ;) |
Your 5.3 intake should fit the heads no problem. The Lq9 has 317 heads and your 5.3 has 243 or 799 heads that are almost the exact same head as the 317 but with smaller combustion chambers.
