02 SIMMS KICK CODES
Old Oct 20, 2002 | 11:20 PM
SS SLP2's Avatar
11 Second Club
Default 02 SIMMS KICK CODES
gut cats Add 02 simms (new)4 weeks ago to 2000 5.3 silverado,and each day will set codes on both banks, clear code with a-tap will set next day ,remove simms and install on 1999 5.3 ( supplier states simms will work on 98-01 5.3) does not set codes reinstall on first truck ,you gessed it -sets codes
any one know answer ??
Thanks for any/all replys Johnny
Old Oct 21, 2002 | 01:07 PM
SS SLP2's Avatar
11 Second Club
Default Re: 02 SIMMS KICK CODES
Thanks for the reply ,I uesing on 00
Old Oct 21, 2002 | 01:12 PM
XLR8NSS's Avatar
Adkoonerstrator
Hmmm...that's strange. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Maybe check the rear O2 wiring harness on the 2000 to see if the wires are burned or nicked. Maybe that is causing the code and not the actual SIMMS.
Good luck <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
Old Oct 21, 2002 | 02:30 PM
BigTex's Avatar
Did you have to splice in your simms?
For the year 00 trucks, GM has 2 different makes of O2 sensors, and they arent compatible between the two types.
Old Oct 21, 2002 | 02:38 PM
SS SLP2's Avatar
11 Second Club
NO did not splice anything
BUT tell me more about the two differant kind of
simms gm used so that I may inquire as to the 02 simms my supplier shipped
thanks Johnny
Old Oct 21, 2002 | 02:56 PM
BigTex's Avatar
Here you go:
Information - Heated Oxygen Sensor Identification and Usage #99-06-04-020
2000 Chevrolet and GMC C/K Models (Silverado and Sierra)with 4.8 L or 5.3 L V8 Engine (VINs V, T -- RPOs LM7, LR)
Two different styles of Heated Oxygen Sensors are used in the 2000 model year truck production.
Vehicles built at the Ft. Wayne (VIN Plant code Z) and Pontiac East (VIN Plant code E) assembly plants will use the Delphi Heated Oxygen Sensors.
Vehicles built at the Oshawa assembly plant (RPO OSG, VIN Plant code 1) will use the Denso Heated Oxygen Sensor.
<img src="http://www.z71.net/o2sensor.jpg" alt=" - " />
FIGURE: Heated Oxygen Sensor Identification
(1) 1 - Typical Bank 1 Sensor 1, Bank 2 Sensor 1 Delphi Heated Oxygen Sensor
(2) Typical Bank 1 Sensor 2, Bank 2 Sensor 2 Delphi Heated Oxygen Sensor
(3) Location of single key on black connector (Delphi Sensor)
(4) Typical Denso Heated Oxygen Sensor, all locations
(5) Location of two key's on gray connector (Denso Sensor)
<small>[ October 21, 2002, 03:00 PM: Message edited by: BigTex ]</small>
Old Oct 21, 2002 | 03:36 PM
SS SLP2's Avatar
11 Second Club
THANKS BIG TEX
will try to check this out
thanks again Johnny
Old Oct 22, 2002 | 12:19 AM
maybe because they aren't made for 02? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 22, 2002 | 10:03 PM
bowtieboyz1's Avatar
i have also got a code from my o2 sims but they have been on for about 6months. i think the sim is bad on one side
Idryfly5
Sep 2, 2022 08:55 PM
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
