** PICS INCLUDED**took my oil pan/windage off 5.3 and seen this
I bought this 5.3 two months ago, but just got around to checking bottom end. This is what I seen...
Is this normal???
There also was a small amount of water in oil pan as you can see..
What do you guys think?
Is this normal???
I was planning on using it in a swap, but I don't believe I'll use it now. I also have a 4.8. I will take the oil pan/tray off tomorrow and post pics of how it looks...
I’d get some brake clean and clean the oil pan out on the 5.3 and make sure there’s no metal debri in it. More than likely what happened with the 5.3 is it sat up for a while and water got in through the intake ports... any time i take a motor out and it’s gonna be hanging around outside, I always loosen the rocker arm bolts so the valves close. Either way, both motors had horrible service life!!!
