why is my fti 3200 stall only stalling to 2800? Vids!!
hey everyone..i got my fti3200 stall converter installed 3 days ago and so far no major issues..really gets up and going now..only issue i have is that when i brake stall it or just go wot from a dead stop it only stalls to 2800..now i noticed when im moving if i flash the stall it will go up to 2800 but once i put it in tow/haul mode which is set to sport mode my black bear it will flash to 3200...but even in tow/haul mode it will not stall to 3200 from a stop...i am still waiting on the s retune from blackbear for the stall..so is it possible that the tune can fix this issue?
i know you cannot tune for the stall speed but i was told that the stock tunes will pull timing when they feel that the tranny is "slipping" alot which would lower the power any thoughts? |
my fti 4600 stalls 6,000 :jest: you wont be able to see the true stall rating of your converter without a trans-brake. your foot brake wont hold the power before it brakes traction.
actually mines does not break traction yet..it stalls to 2800 without any spin..even from a dead stop and just going WOT
Torque converter stall ratings are at best an estimate based on some arbitrary torque input. There is no standardization of the ratings between different companies.
You need to make more power. You can have them loosen the converter up if you send it back.
(Post 5222145)
you can put your foot to the floor and never break traction? wish i had that problem.
nope!! with a tune lt headers small cam nd stall and i cannot break my tires loose still :( dammit! but alright i guess i just gotta make more power then..what would you guys recommend next as far as power adder staying NA? 243 heads? intake manifold with bigger throttle body?
screw N/A. you're playing with a heavy pig. go ahead and jump into nitrous or F/I
What gears to you have?
