Vibration at 80-90 only at WOT not crusing, leaf spring bushings??
Old Mar 12, 2012 | 11:31 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by Phantom
My truck never vibrated until I did the 4l80 swap. My pinion angle just went retarded positive, like +7. Got it back to where I wanted it on the negative side and everything is smooth again
Did you just use axle shims or raise/lower the tranny or both?
Old Mar 12, 2012 | 11:32 AM
Phantom's Avatar
11 Second Club
Cut and re welded new brackets on the axle
Old Mar 12, 2012 | 12:24 PM
brandon6.0's Avatar
what drop are u setting at corey? i had to add 6* shims on mine.
Old Mar 12, 2012 | 12:47 PM
BlackGMC's Avatar
Resident Retard
I have a 2/3 drop, but it seems lower than most 2/4s
Old Mar 12, 2012 | 12:54 PM
brandon6.0's Avatar
ok. I have heard that just about everyone who has swapped to a 4l80 has had to shim the rearend. I have a flip kit so i definitely had to shim mine.
Old Mar 12, 2012 | 02:21 PM
BlackGMC's Avatar
Resident Retard
Ya, i am deciding on shiming versus cutting off the spring perches and welding up some new one...
Old Mar 12, 2012 | 02:39 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Re-welding spring perches > axle shims. But either way gets the job done. If you use shims, you'll need to replace the center bolt in your leaf packs to one with a longer head on it. The stock bolt head is too short to go thru the shim and still locate the perch.
Old Mar 12, 2012 | 03:07 PM
BlackGMC's Avatar
Resident Retard
Agreed, but i think i am going to use shims first just to prove that is the issue. Then this summer when i relocate the shocks I will strip the axle down and redo the perches....
The shims i have order come with a new bolt so i am good there. Hopefully this resolves my issue....
Old Mar 12, 2012 | 05:39 PM
GMCtrk's Avatar
Mine has vibrated for the past 2 years since the 80e swap. I basically resolved it by shimming the trans up. But mine is basically due to a scewed up sriveshaft. I am planning to swap to a 1 piece ds because getting all the angles correct with the 2 pc shaft is a real headache. I just need the $650 for the 1 pc shaft. If you do have a vib i would recommend fixing it asap bc it will take out your tranny tailshaft seal and/or bushing or the rear pinion seal
Old Mar 12, 2012 | 05:43 PM
BlackGMC's Avatar
Resident Retard
Ya i have shims on order right now. I am just not going heavy throttle. That is where i get the vibration.
I just measures everything again.
Rearend +4
Driveshaft -1
Transmission -4.
So the angles are way off. I should have it better this weekend.
