Originally Posted by Vince @ FLT
(Post 4568607)
One other thing to check is the boost valve. I have seen where the snap ring does not get fully installed and cause this issue as well. Recently I have seen some issues with the TG boost valve sleeve. Make sure that both holes do not have any burs in the holes on the outside of the sleeve. This could cause low boost pressure when in reverse as well. Good luck getting it all sorted out and please make sure to report back what you find. Vince
Originally Posted by fredkj3
(Post 4569029)
yes ^ that happened to me the snap ring wasnt in all the way and actually the boost valve fell out... i was on the lift, tryed to back off and i had no reverse......
http://i276.photobucket.com/albums/k...p/transpan.jpg LOLOL snap ring must not have been in correctly. thanks again guys. especially vince. |
haha aleast you found the problem easy enough. btw your rear tires should move when the truck is up on the lift mine does but it wont move at all on the ground until you give it gas like stated cause of the 3600 stall.
Ding.Ding.Ding.Ding. I think we have a winner! :jest: Glad to help. Vince
kurt- we backed the truck out of the garage but it kept stalling. we have a few codes on which hopefully can be corrected with a tune.
thanks again vince
