truck only revs to ~2000rpm when brake stalling
Old Nov 15, 2006 | 12:59 PM
adam1803's Avatar
Default truck only revs to ~2000rpm when brake stalling
I've got a 3200 stall in the truck and when i brake and try to stall it up it will only go to about 2k and won't rev anymore. Maybe this should be in the tuning section. Is there something in the PCM that controls this?
Old Nov 15, 2006 | 01:05 PM
BlackGMC's Avatar
Resident Retard
I may be wrong but doesn't the PCM have a Brake TQ Management table that removes timing when the brakes are applied under a load?
Old Nov 15, 2006 | 01:07 PM
adam1803's Avatar
i didn't see anything about it in HPT but i'll take a look, i've been known to miss the obvious before, lol.
Old Nov 15, 2006 | 03:34 PM
silver-mod-o's Avatar
Hunt&Fisherator
brake stall is NOT actuall stall... besides, those stall numbers slapped on converters are just approximate #'s....
Old Nov 15, 2006 | 04:09 PM
DrX's Avatar
DrX
Old Nov 15, 2006 | 04:13 PM
BlackGMC's Avatar
Resident Retard
I thought there was a setting.
Old Nov 15, 2006 | 05:17 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Dr X..... what would you set B0401 at? Is that your table in the picture?
Old Nov 15, 2006 | 05:54 PM
thunder550's Avatar
High on diesel fumes
In the description in EFILive it says something about how it reduces power in ETC vehicles....does that mean ETC vehicles only?
Old Nov 15, 2006 | 08:05 PM
DrX's Avatar
DrX
Yes that is/was mine. I just set it high so it would never be an issue. Don't think I'll ever be brake stalling to 8000 RPM.
Could be. I only see it in ETC truck tunes. First one being an 01 Tahoe.
Upgrading to an 02 PCM, as many have done, would definitely give you BTM.
Old Nov 15, 2006 | 08:28 PM
delete all torque management of the tranny if modded if not modded delete 60%-75% only. Also try stalling the truck in second gear with tow haul button on and see how far does it go now...........
