Transmission won't set against my engine!
17 Attachment(s)
I'm having a hard time seating my transmission up against my engine. As a quick recap here's what I did leading up to it...
I dropped in the converter and listened for all three "clicks" and think I got them all. :emb: I think the gap between the converter pads and the bellhousing is supposed to be 1.030" and it looks like I got that... Attachment 146692 Attachment 146693 I did my best to install the tranny after that. I don't have the ceiling clearance to roll the tranny under the truck via a floorjack so I had to slide it in first on a blanket and then lift it up onto a jack afterwards. Needed the help of some friends and it still wasn't the easiest way to go!! Ceiling clearance FTL!! :bang: Attachment 146694 Attachment 146695 Kinda used everything I could to make this happen with the floor jack that I have but in the end I think I got it in place and somewhat lined up. Attachment 146696 Attachment 146697 So here's where the dilemma lies... I have the tranny as far forward as I can go as evidence by the tranny mount that's on top of the crossmember... Attachment 146698 You can see the bolt is completely forward in the oval slot so I can't squeeze it forward any further. Attachment 146699 I don't have any dowel pins inbetween the tanny and the engine yet and didn't realize it after talking to a buddy. So I'm gonna go grab some tomorrow if I can before going any furthur. However, when I line up the bellhousing to the block there's a 7/16th inch gap between the two. Attachment 146700 Attachment 146701 The inner Converter shaft is still outside the flex plate so that's not binding or impeding it from going into the flexplate center section either... Attachment 146702 Attachment 146703 I've got both the engine and tranny straight up and down so it's not a height or angle position I don't think. Attachment 146704 Attachment 146705 Attachment 146706 Attachment 146707 Attachment 146708 So anyways, I am gonna take a good long look at it tomorrow to see if anything is catching or binding that I missed and hope that's the case. Couple people have already suggested that I flip the tranny mount around to see if the bolt pattern is actually offset, and it was also mentioned that the engine frame mounts might be on backwards because apparently some aren't reversible. Those are two things I'm gonna start with tomorrow but also wanted to see if anyone else has any idea why it might have this gap and/or what I missed. Thanks :) |
ya, you need to get some dowel pins in first. But i'm really not sure whats holding it up from sitting flush. The only thing I could think is the converter hub is hitting/binding on the crank.
see if the converter goes in the crank by itself and see if the transmission sits flush to the engine without the transmission. looks like the only thing holding you up in the pictures is the transmission mount bolt. a 4l60e came out of the truck right? dont the 4l80e and 4l60e have different crossmembers? or at least mount in different places on the crossmember?
based on what I can see, it looks like the trans is sitting at an angle compared to the engine block. I would say your problem lies with the crossmember.
While i've never done the swap the crossmember seems to be the culprit.
You said its as far forward as it will go on the crossmember and it still isn't hitting the engine. Take it off the crossmember and I bet it'll go further. |
I swear that I've read somewhere that the rubber tranny mount is offset. You might try to unbolt it and flip it 180*. I just don't know if flipping it will hurt you or help you....
Originally Posted by viciousknid
(Post 4258041)
Yup yup!! You are all more or less right! I found what I think is the culprit and will post up a picture of it later when I get my camera back from my garage! Thanks for the replies, it actually helped be find the prob...will post up more later.
:usa: |
your lucky the problem didn't have teeth and venom
1 Attachment(s)
Originally Posted by 454navyss
(Post 4258030)
Originally Posted by Coban
(Post 4258113)
Here is the side profile of the mount...kinda wish I would of thought of this alot sooner!! :bang: Attachment 146709 I ordered a polyurethane transmission mount from summit along with some dowel pins since I can't move forward without the dowel pins, figured since I have to pull the mount back out might as well spend $10 on a new one.
(Post 4258280)
| All times are GMT -5. The time now is 01:31 AM. |
