Transmission recommendations
I have a 2005 GMC Sierra Z71 4x4. I am currently doing an LQ9 swap and will be in the 500 - 530 hp range (flywheel). I am using the truck for a fun weekend truck/light towing. Light towing meaning an aluminum car trailer with a few 4wheelers on it. I have the original trans with 150k on it and its the 4L65E I believe and I know the trans won't hold up as soon as this swap is complete so I just want to do it now and be done with it. I do not want to do the 4L80E swap either. I don't have time to do the fabrication. What companies do you recommend or should I stay away from? I am looking to spend between $2k - $3k with everything, torque converter and cooler included. I was looking at the trans from texas speed with a 2600 stall. Anyone have any experience? It should work with the transfer case, correct?
Robert Godfrey aka Transbuilderguy built me a hell of a trans with a warranty and for a great price.
Where is he located? Does he offer a warranty? Did he use your original trans?
Originally Posted by outlawz2004
(Post 5297830)
For a 4L65e Godfry is pretty much as good as they come.
Question though.... Why do you think the fabrication will be so rough on the 80e? Dirttrackracer makes a bolton crossmember. Beyond that there isn't any serious fabrication. It would be easy to stay under budget with a proper torque converter and a mild 80e. Best budget trans cooler is the stock ford excursion cooler. |
It's not a ton of fabrication but I just don't have the time right now to be doing this swap. Getting a new driveshaft, the harness, the tuning. I am a little crunched for time. The truck has been down since November and I bought an 04 Mercury Marauder to drive while I fixed the truck. Well I made 3 payments on the Marauder and a girl on her cell phone blew the red light and totaled the car. So I am borrowing a car at the moment and don't want to tie it up too long. I have never done the swap but I have researched it plenty and I am just not prepared to do the swap at this point in time with everything else going on.
Originally Posted by gamble686
(Post 5297838)
Question though.... Why do you think the fabrication will be so rough on the 80e? Dirttrackracer makes a bolton crossmember. Beyond that there isn't any serious fabrication. It would be easy to stay under budget with a proper torque converter and a mild 80e. |
No driveshaft needed for my 80E swap, I had to get a different yoke and used Tyler's crossmember. I was stressed about it leading up to the swap. Afterwards, wondered why I worried so much about it. 80Es are damn near bomb proof in stock form.
Originally Posted by CammedZ71
(Post 5297831)
Originally Posted by 86 IROC
(Post 5297853)
Yea I'm assuming a little more work with 4wd.
(Post 5297859)
That works on a 2wd but not a 4wd.
