-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   Trans temp sensor resistance? (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/trans-temp-sensor-resistance-511248/)
Ferocity02 Dec 3, 2012 12:38 PM
Anyone know the resistance of the 4L60E trans temp sensor? I need to put in a resistor to trick the computer into thinking the sensor is still there so I can use a Tech II to do the ABS bleed procedure.
nonnieselman Dec 3, 2012 12:45 PM
i can measure one when i get home.
Ferocity02 Dec 3, 2012 12:54 PM
Sweet, thanks!
I did find this however, not sure if it's valid:
https://ls1tech.com/forums/pcm-diagn...esistance.html
https://ls1tech.com/forums/attachmen...ance-chart.gif
https://ls1tech.com/forums/attachmen...ance-graph.gif
nonnieselman Dec 3, 2012 12:55 PM
Dang C*!!!
Atomic Dec 3, 2012 01:36 PM
F = 1.8*c +32
