Trans temp sensor resistance?
Anyone know the resistance of the 4L60E trans temp sensor? I need to put in a resistor to trick the computer into thinking the sensor is still there so I can use a Tech II to do the ABS bleed procedure.
Sweet, thanks!
I did find this however, not sure if it's valid:
https://ls1tech.com/forums/pcm-diagn...esistance.html
Nimoryan
Jul 5, 2015 03:50 PM
4l60e, chart, current, ford, graph, location, resistance, resistence, sensor, temp, temperature, tempureture, trans, transmission, versus
