trans temp gauge
Yes..
Look for a Automer Trans Temp gauge.
Its goin to come with a 1/8" NPT sensor, you can remove the pressure port plug above the Park Neutral Safety switch on the driver side of transmission. Put sensor in and good to go.
It connects to OBD II connector and gives you all data in to readings at the same time. It can read DTC and clears it.
Nimoryan
Jul 5, 2015 03:50 PM
